12 years agocyclone II ALTLVDS_RX ipcore issue?
i am using ALTLVDS_RX ipcore on cyclone II device, but meet a problem that rx parral datas are not correct. the following is the ipcore configration. any advice? ALTLVDS_RX_component.buffe...
12 years ago --- Quote Start --- If it is really urgent then you need to describe your problem better. What are you trying to achieve and what do you get instead? "rx parral datas are not correct" isn't really helping --- Quote End --- ok, lvds data is from a RGB generater, i can control the RGB generater and generate any RGB data, for example all one , all zero, increment data. when i send increment data to lvds interface, altlvds_rx ip should recover 56bits increment data, but failed. some bits happen error.
