Cyclone 10 GX DisplayPort Rx
Hello dlim,
I modified the custom Dipalyport Receiver board. The Modified point is CLKUSR pin only
DisplayPort Receiver function still doesn't work.
I attached two picture.
Picture 1 : cyclone 10gx transceiver PHY user Guide (20.1) page 259
Picture 1: I probing from my board.
In my system, the rx_is_lockedtodata signal and rx_is_lockedtoref are always low (it is problem)
Can you advice how to make it to work ?
My concern is rx_cal_busy and rx_analogreset signal is overlapping (?)
I didn't change anything in bitec-reconfig_alt_c10.v and xcve_reconfig_arbiter.sv.
I checked all reconfiguration signals. it works good.
the calibration step works good because rx_analogreset asserted.
I think the PLL(rx_cdr_refclk0 : 135MHz) doesn't lock.
Michael
- Deshi_Intel
Hi Michael,
Good news indeed !
So you are saying there is wrong DP signal assignment on your custom board ? Then you fixed it.
After that, is your custom board DP functionality working now ? or you still face some issue ?
dlim
- Michael2021
I removed the repeater chip control (using PIC Controller firmware : was blocked training sequence)
and DP rx_serial_input port was assigned reverse (But Still I can't understand)
Now my custom board works good.
My next concern is how to increase 8.1G data rate. There is no option in Non GPU DisplayPort mode (Max 5.4G)
Thank you
Michael
- Deshi_Intel
Are you using very old Quartus version ?
- I do a quick check on v20.4 Quartus Pro and I can see that C10 GX FPGA DP IP did support till 8.1G.
The other thing to take note is for 8.1G (HBR3) support, it recommended to use repeater/retimer for DP Rx side. Checkout below link page 8, table 8
dlim
- Michael2021
Thank you so much
Michael
- Michael2021
Hello
I am doing DisplayPort comparability test.
I found Desktop PC included Video card detect right resolution but the some laptop PC doesn't output video signal due to detect wrong resolution. My DP core is non GUP mode so I can't find the problem. I guess the reason of trouble is in DP Link training sequence.
Can you recommend how to solve the problem ?
Thank you
Michael
- Deshi_Intel
Hi Michael,
You are welcome !
FYI... Intel support structure is on a case by case basic.
For now, I am setting this case to closure but feel free to post new forum thread if you still have new enquiry in future.
dlim
- Michael2021
I can't find how to open new case ?
