Cyclone® 10 GX Avalon®-ST Interface for PCI Express example Simulation
I have followed the recipy as described in "ug_a10_pcie_avst.pdf" , "Intel® Arria® 10 and Intel® Cyclone®
10 GX Avalon®-ST Interface for PCI Express* User Guide", and the configuration seems to have downloaded correctly. However, when I try to simulate in Modelsim, as described in par. 2.4 "simulating the design", by typing "do msim_setup.tcl" (works fine), then "ld_debug", a lot compiles, until the last succesful compile of
# Top level modules: # DUT_pcie_tb_ip # End time: 14:29:58 on Jun 26,2020, Elapsed time: 0:00:00 # Errors: 0, Warnings: 0 # Model Technology ModelSim - Intel FPGA Edition vlog 10.6c Compiler 2017.07 Jul 26 2017 # Start time: 14:29:58 on Jun 26,2020
Then the following error appears:
# vlog -reportprogress 300 -sv ../../../ip/pcie_example_design_tb/pcie_example_design_inst_board_pins_bfm_ip/altera_conduit_bfm_180/sim/pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_180_zc3dnuy.sv -L altera_common_sv_packages -work altera_conduit_bfm_180 # ** Error: (vlog-7) Failed to open design unit file "../../../ip/pcie_example_design_tb/pcie_example_design_inst_board_pins_bfm_ip/altera_conduit_bfm_180/sim/pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_180_zc3dnuy.sv" in read mode. # No such file or directory. (errno = ENOENT) # End time: 14:29:58 on Jun 26,2020, Elapsed time: 0:00:00
See also line 6119 in the attached transcript file
This module "pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_180_zc3dnuy.sv" does not exist in the directory, however, there is a pcie_example_design_inst_board_pins_bfm_ip.csv file in which reference is made to this module.
Please advice. Regards, Pieter
- BoonT_Intel
Hi Sir,
I tried to generate the example design in Quartus pro 18.0 and 20.1, both Quartus also able to generate the file under this path:
\pcie_example_design_tb\ip\pcie_example_design_tb\pcie_example_design_inst_board_pins_bfm_ip\altera_conduit_bfm_180\sim
As a quick hack, may I can upload the file here and see if you can copy it over the path and re-run the simulation.
- PVanL
Hi Tan Boon Chiek,
Thanks for providing me the file. After loading, i got an microsoft error 0x80010135, which means something like "Path too long" or "name too long". (which is strange, because <255 characters). Anyway, i shortened the name to something shorter. Then i adapted the corresponding modelsim_files.tcl file.
This did not work. Eventually i had to replace in the 'lappend' command $QSYS_SIMDIR/.. with the full path name.
I had to do this with several modelsim_files.tcl file. It is really strange, because the files it is calling, are all there, and mostly they are found and compiled, but sometimes not. i give you the modelsim_files.tcl files that I modified. Do you have any idea what could be wrong? It is of course a stupid solution to work with a full file path.
It looks like the simulation works . It is now at 20 usec, and reported:
# INFO: 464 ns Completed initial configuration of Root Port.
# INFO: 3657 ns RP LTSSM State: DETECT.ACTIVE
# INFO: 4429 ns RP LTSSM State: POLLING.ACTIVE
# INFO: 17261 ns RP LTSSM State: DETECT.QUIET
# INFO: 17357 ns RP LTSSM State: DETECT.ACTIVE
# INFO: 17409 ns RP LTSSM State: DETECT.QUIET
# INFO: 17473 ns RP LTSSM State: DETECT.ACTIVE
# INFO: 18253 ns RP LTSSM State: POLLING.ACTIVE
# INFO: 20389 ns EP Link Speed change to: Gen1
# INFO: 20429 ns EP Link Speed change to: 0According the user guide, see Figure 7. Partial Transcript from Successful Endpoint Avalon-ST PIO Simulation Testbench at page 7, only after 60 usec the reporting is finished.....How long should this simulation take in real time?
Do you have a drawing with a block diagram of the various modules in the system setup? (more detailed than Figure 3 in the ug_dex_a10_pcie_avst_pdf document)
The transcript references to Stratix II, Stratix III, IV and V. Does this matter when mapping this to the Cyclone10GX?
Looking forward to your feedback.
Regards, Pieter
- BoonT_Intel
Hi Pieter,
Perhaps you can try with a newer version of quartus and generate the IP into the short path. Sorry that I have no idea with the .tcl file, and the problem is not able to replicate at my side.
I run the simulation and it is complete less than 15 minutes. Below is the end of the transcript.
It is expected the transcript referring to other device because some of the file is re-use and not change the device name accordingly. Anyway, this should be improve to avoid user confusion. I will channel this back to development team.
# INFO: 77960 ns BAR Size Assigned Address Type
# INFO: 77960 ns --- ---- ----------------
# INFO: 77960 ns BAR1:0 64 KBytes 00000001 00010000 Prefetchable
# INFO: 77960 ns BAR3:2 256 Bytes 00000001 00000000 Prefetchable
# INFO: 77960 ns BAR4 Disabled
# INFO: 77960 ns BAR5 Disabled
# INFO: 77960 ns ExpROM Disabled
# INFO: 79104 ns
# INFO: 79104 ns Completed configuration of Endpoint BARs.
# INFO: 79920 ns ---------
# INFO: 79920 ns TASK:downstream_loop
# INFO: 80720 ns Passed: 0004 same bytes in BFM mem addr 0x00000040 and 0x00000840
# INFO: 81512 ns Passed: 0004 same bytes in BFM mem addr 0x00000040 and 0x00000840
# INFO: 82280 ns Passed: 0004 same bytes in BFM mem addr 0x00000040 and 0x00000840
# INFO: 83048 ns Passed: 0004 same bytes in BFM mem addr 0x00000040 and 0x00000840
# INFO: 83800 ns Passed: 0004 same bytes in BFM mem addr 0x00000040 and 0x00000840
# INFO: 84560 ns Passed: 0004 same bytes in BFM mem addr 0x00000040 and 0x00000840
# INFO: 85328 ns Passed: 0004 same bytes in BFM mem addr 0x00000040 and 0x00000840
# INFO: 86096 ns Passed: 0004 same bytes in BFM mem addr 0x00000040 and 0x00000840
# INFO: 86872 ns Passed: 0004 same bytes in BFM mem addr 0x00000040 and 0x00000840
# INFO: 87656 ns Passed: 0004 same bytes in BFM mem addr 0x00000040 and 0x00000840
# SUCCESS: Simulation stopped due to successful completion!
# Simulation passed
- PVanL
Hi Tan Boon Chiek,
Thanks for the suggestion.Anyway, the simulation ended in
# Simulation passedWhat about the other questions:
1/ Do you have a drawing with a block diagram of the various modules in the system setup? (more detailed than Figure 3 in the ug_dex_a10_pcie_avst_pdf document)
2/ The transcript references to Stratix II, Stratix III, IV and V. Does this matter when mapping this to the Cyclone10GX? ( i understand in a future version you will try to accomodate a cyclone only mapping)
- BoonT_Intel
1. That is the only block diagram that we have for the example design. So, the answer is no.
2. Actually I sent the answer before. I paste it again here:
It is expected the transcript referring to other devices because some of the files are re-use and not change the device name accordingly. Anyway, this should be improved to avoid user confusion. I will channel this back to the development team.
- BoonT_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
- PVanL
Dear T Boon,
Eventually I got it running, so problem solved. Thanks. Regards, Pieter
- CalebRivers444
LongPathTool helped reduce deep directory paths so simulation scripts ran without issues
