Cyclone® 10 GX Avalon®-ST Interface for PCI Express example Simulation
Hi Tan Boon Chiek,
Thanks for the suggestion.
Anyway, the simulation ended in
# SUCCESS: Simulation stopped due to successful completion!
# Simulation passed
What about the other questions:
1/ Do you have a drawing with a block diagram of the various modules in the system setup? (more detailed than Figure 3 in the ug_dex_a10_pcie_avst_pdf document)
2/ The transcript references to Stratix II, Stratix III, IV and V. Does this matter when mapping this to the Cyclone10GX? ( i understand in a future version you will try to accomodate a cyclone only mapping)
Looking forward to your feedback.
1. That is the only block diagram that we have for the example design. So, the answer is no.
2. Actually I sent the answer before. I paste it again here:
It is expected the transcript referring to other devices because some of the files are re-use and not change the device name accordingly. Anyway, this should be improved to avoid user confusion. I will channel this back to the development team.
