RicardoC
3 years agoCXL Type 3 OOO IP AXI issue
Hi, After populating the AFU with custom logic, the AXI interface from the CXL IP seems to have incorrect behavior. Scenario: standard Avery base testbench attempts to write 1500 CLs to the device....
JonWay_altera
3 years agoHi @RicardoC This is a bug in 23.2 when OOO is enabled. You can work around this until 23.3 by de-asserting AWREADY and WREADY together if they need to backpressure either the Address or Write data channel.
- RicardoC3 years ago
Hi John,
Thank you for the confirmation. We had already worked around the issue in the same manner as you suggested.
Thanks again,
Ricardo.
