9 years agoCVI overflow and CVO underflow
CVI(run control) -- CVO(run control) , cvi always overflow,cvo always underflow. why? How to set the fifo depth? nios config code is as follows, /**************************** CTI **************************************/ printf("/*******************************************\n"); printf("CTI_control is %x!\n",CTI->control ); printf("CTI_STATUS is %x!\n",CTI->status ); printf("\n"); // // updata control data // CTI->control = 0x0006; // // set go bit 1 // CTI->control = CTI->control | 0x0001; printf("After config.\n"); printf("CTI_control is %x!\n",CTI->control ); printf("CTI_STATUS is %x!\n",CTI->status ); printf("\n"); // /************************** ITC ****************************************/ printf("/*******************************************\n"); // // mode1 HD // disable mode1_valid ITC->mode1_valid = 0; // set mode1 registers ITC->mode1_control = 1; ITC->mode1_sample_count = 1920; ITC->mode1_f0_line_count = 540; ITC->mode1_f1_line_count = 540; ITC->mode1_hfront_porch = 0; ITC->mode1_hsyn_length = 0; ITC->mode1_h_blanking = 720; ITC->mode1_vfront_porch = 0; ITC->mode1_vsync_length = 0; ITC->mode1_v_blanking = 22; ITC->mode1_f0_vfront_porch = 0; ITC->mode1_f0_vsync_length = 0; ITC->mode1_f0_v_blanking = 23; ITC->mode1_active_picture_line = 21; ITC->mode1_f0_v_rising = 561; ITC->mode1_field_rising = 564; ITC->mode1_field_falling = 1; ITC->mode1_std = 0; // ITC->mode1_sof_sample; // ITC->mode1_sof_line; // ITC->mode1_vcoclk_div; ITC->mode1_ancillary_line = 9; ITC->mode1_f0_ancillary_line = 571; // enable mode1_valid ITC->mode1_valid = 1; // // mode2 SD // disbale mode1_valid ITC->mode2_valid = 0; // set mode1 registers ITC->mode2_control = 3; ITC->mode2_sample_count = 720; ITC->mode2_f0_line_count = 288; ITC->mode2_f1_line_count = 288; ITC->mode2_hfront_porch = 0; ITC->mode2_hsyn_length = 0; ITC->mode2_h_blanking = 144; ITC->mode2_vfront_porch = 0; ITC->mode2_vsync_length = 0; ITC->mode2_v_blanking = 24; ITC->mode2_f0_vfront_porch = 0; ITC->mode2_f0_vsync_length = 0; ITC->mode2_f0_v_blanking = 25; ITC->mode2_active_picture_line = 23; ITC->mode2_f0_v_rising = 311; ITC->mode2_field_rising = 313; ITC->mode2_field_falling = 1; ITC->mode2_std = 0; // ITC->mode2_sof_sample; // ITC->mode2_sof_line; // ITC->mode2_vcoclk_div; ITC->mode2_ancillary_line = 8; ITC->mode2_f0_ancillary_line = 321; // enable mode2_valid ITC->mode2_valid = 1; printf("ITC control is %x!\n",ITC->control ); printf("ITC status is %x!\n",ITC->status ); // enbale control, cvo output data ITC->control = 0x1e; ITC->control = ITC->control | 0x01;1 Reply
This is normal that the CVI overflow or CVO underflow if without a frame buffer at between. In the real system this is suggested to have a frame buffer: CVI-> FB -> CVO. Best Regards, Terence (This message was posted on behalf of Intel Corporation)
