9 years agoCVI overflow and CVO underflow
Hi, CVI(run control) -- CVO(run control) , cvi always overflow,cvo always underflow. why? How to set the fifo depth? nios config code is as follows, /***********...
8 years agoHi,
This is normal that the CVI overflow or CVO underflow if without a frame buffer at between. In the real system this is suggested to have a frame buffer: CVI-> FB -> CVO. Best Regards, Terence (This message was posted on behalf of Intel Corporation)
