11 years agoCustom PHY 8b/10b test fails but 8b is OK
Hi, I am trying to validate my Custom PHY design with the transceiver toolkit. I am using the transceiver toolkit to generate test-patterns. My setup is very similar to the setup in The Transce...
11 years agoHello,
Even if this thread is a bit old I too would like to know if you had any luck in getting the custom PHY working with the 8b10b encoding. I have been working with this module since it is required to be instantiated for the SerialLiteII core when working with Stratix V devices, but I seem to have the same symptoms as you:- I am able to simulate correctly.
- The tx portion of the PHY is able to apparently transmit the patterns correctly.
- The receiver side simply ignores the input packets, never asserting the stat_rr_link signal, nor giving any indication that it is seeing something at its input.
