11 years agoCustom PHY 8b/10b test fails but 8b is OK
Hi, I am trying to validate my Custom PHY design with the transceiver toolkit. I am using the transceiver toolkit to generate test-patterns. My setup is very similar to the setup in The Transce...
11 years agoHi Peter,
I just read your post, do you finally succeed to run your Cyclone V design (with 8b10b) on the Transceiver Toolkit ? I have a very similar problem with a Stratix V GX. I start from an Altera example design for Stratix V GX, it runs correctly with my SI Dev Kit board with the Transceiver toolkit. Then I modify the example design, I mainly enable the 8B10B codec on the XCVR Custom PHY and increase the word alignment length accordingly. When I test this modified example: - The Tx transceiver seems to run correctly - For the Rx transceiver, the indicator "RX CDR locked to data" is green but the Receiver Channel remains in Yellow with the following indication: "TOOLTIP_STATUS_RECEIVER_CHECKING_BUT_NOT_LOCKED"... The behaviour is similar with and without the check of option "enable word aligner" Thanks in advance for your help. Regards Mike
