11 years agoCustom PHY 8b/10b test fails but 8b is OK
Hi, I am trying to validate my Custom PHY design with the transceiver toolkit. I am using the transceiver toolkit to generate test-patterns. My setup is very similar to the setup in The Transce...
11 years agoOK, the timing violations seem to be "harmless" as they were associated with the the pattern generator. Altera has set a false path on them in their cyclone v gs reference designs (http://www.altera.com/support/examples/on-chip-debugging/on-chip-debugging.html) as well:
set_false_path -from
set_false_path -from .gpll~PLL_OUTPUT_COUNTER|divclk}] -to .gen_bonded_group.av_xcvr_native_inst|inst_av_pcs|ch.inst_av_pcs_ch|inst_av_hssi_8g_rx_pcs|wys|rcvdclkpma}]
set_false_path -from .gpll~PLL_OUTPUT_COUNTER|divclk}] -to .gen_bonded_group.av_xcvr_native_inst|inst_av_pcs|ch.inst_av_pcs_ch|inst_av_hssi_8g_tx_pcs|wys|txpmalocalclk}]
(Besides, they showed up without the 8b/10b interface, and there, the test ran fine....) So Back to the original problem: What am I doing wrong?
