11 years agoCustom IP problem
Hai, I am using Qsys to integrate all the custom IPs developed.I am using NiosII SBT to access the IPs. When i add a new IP to Qsys and try to access from Nios,its not working.Does anyone have t...
11 years agoSir,
I have check the power level and the clock .That seems to be ok. Also with normal schematic file quartus project i am able to run the program in FPGA.But when i try to use the Nios,then only i am getting all these probs. If i am using the PIO's as output only.Then i am able to work with the project.But if i configure them as bidirectional and set its direction as output,then only its creating the problem.
