11 years agoCustom IP problem
Hai, I am using Qsys to integrate all the custom IPs developed.I am using NiosII SBT to access the IPs. When i add a new IP to Qsys and try to access from Nios,its not working.Does anyone have t...
11 years ago --- Quote Start --- this is a custom made development board for Cyclone IV series. --- Quote End --- You may want to consider getting a sanity check on your Quartus/Qsys/NIOS projects using a commercial board. On your custom board, you need to check all of the usual things whenever you build a new board (power, clock, etc.) Your symptom sounds a lot like the FPGA itself is resetting or reconfiguring, possibly a board/design defect.
