11 years agoCustom IP problem
Hai, I am using Qsys to integrate all the custom IPs developed.I am using NiosII SBT to access the IPs. When i add a new IP to Qsys and try to access from Nios,its not working.Does anyone have t...
11 years agohello manjurgl.
do you think reset is active high? normally reset pin of NiosII ( I mean Qsys ) is active low. if you insist it is active high, that is fine. could you upload your Qsys file on this page? I think I can help you.
