11 years agoCustom IP problem
Hai, I am using Qsys to integrate all the custom IPs developed.I am using NiosII SBT to access the IPs. When i add a new IP to Qsys and try to access from Nios,its not working.Does anyone have t...
11 years agoHai all,
Thanks for your replies.I have removed the custom IPs and started building the Qsys with only PIO's. Now I have added upto 45 no: of PIO's in the Qsys and generated the system.After that i have build the quartus project with the generated Qsys. Then i used Nios SBT for debugging.During the debug for the helloworld.c program itself it get resetted.What can be the reason for the reset? I have ensured in the hardware that the pin which is assigned as the reset pin of the nios is active high .Is there any limitation in the no: of PIO's which can be used in a Qsys? I am using Cyclone IV EP4CE22E22I7 FPGA based digital controller card for the development.If i reduce the no: of PIO's it is working fine. Please see the attached Qsys image also. Need help in sorting this issue....
