11 years agoCustom IP problem
Hai, I am using Qsys to integrate all the custom IPs developed.I am using NiosII SBT to access the IPs. When i add a new IP to Qsys and try to access from Nios,its not working.Does anyone have t...
11 years agoI do not know what your Qsys condition.
but those are my guess. - who is resetting the nios. it must be you. did you make sure reset pin of Qsys input. if you leave it open which means it is resetting because Qsys reset pin is active low. - Custom IP is not working. how do you check Custom IP? I think you can not check Custom IP as long as Qsys is being reset.
