16 years agoCustom Component, Write not working
Hi, I have just created a SOPC custom component with an Avalon-MM Slave template (clk, reset, write, read, readdata, writedata) with some HDL inside. My problem is that in my C application...
16 years agoWhere is the chipselect signal in your IP ?
yes the avalon specification available here http://www.altera.com/literature/manual/mnl_avalon_spec.pdf?gsa_pos=2&wt.oss_r=1&wt.oss=avalon spec does not include the chipselect input anymore. as your datawidth is 32 bit, i recommend to monitor the byteenable signals as well they tell you what part of your write date is valid. next thing is if avs_s0_read_n = '0' then avs_s0_readdata <= std_logic_vector(fixA_array(P_line,P_column)) ; so your read data is 1 clock delayed valid but i see no waitrequest but a read wait time of 1 maybe the data you expect is avaiable after your access is finished.
