16 years agoCustom Component, Write not working
Hi, I have just created a SOPC custom component with an Avalon-MM Slave template (clk, reset, write, read, readdata, writedata) with some HDL inside. My problem is that in my C application...
16 years agoSorry I didn't provide a lot of informations. I'm not very familiar with Nios and I was just doing some test.
Here is the tcl file :# TCL File Generated by Component Editor 9.0# Thu Aug 27 15:19:24 CEST 2009# DO NOT MODIFY
# +-----------------------------------# | # | Dust_Detect "Dust_Detect" v1.0# | Vvh 2009.08.27.15:19:24# | Dust Detector# | # | D:/altera/90/nios2eds/examples/vhdl/niosII_cycloneII_2c35/Detecteur_Poussiere/Dust_Detect.vhd# | # | ./Dust_Detect.vhd syn, sim# | # +-----------------------------------
# +-----------------------------------# | module Dust_Detect# |
set_module_property DESCRIPTION "Dust Detector"
set_module_property NAME Dust_Detect
set_module_property VERSION 1.0
set_module_property INTERNAL false
set_module_property GROUP "User Component"
set_module_property AUTHOR Vvh
set_module_property DISPLAY_NAME Dust_Detect
set_module_property LIBRARIES {ieee.std_logic_1164.all ieee.numeric_std.all std.standard.all}
set_module_property TOP_LEVEL_HDL_FILE Dust_Detect.vhd
set_module_property TOP_LEVEL_HDL_MODULE Dust_Detect
set_module_property INSTANTIATE_IN_SYSTEM_MODULE true
set_module_property EDITABLE false# | # +-----------------------------------
# +-----------------------------------# | files# |
add_file Dust_Detect.vhd {SYNTHESIS SIMULATION}# | # +-----------------------------------
# +-----------------------------------# | parameters# | # | # +-----------------------------------
# +-----------------------------------# | connection point clock# |
add_interface clock clock end
set_interface_property clock ptfSchematicName ""
set_interface_property clock ENABLED true
add_interface_port clock clk clk Input 1
add_interface_port clock reset_n reset_n Input 1# | # +-----------------------------------
# +-----------------------------------# | connection point s0# |
add_interface s0 avalon end
set_interface_property s0 addressAlignment DYNAMIC
set_interface_property s0 bridgesToMaster ""
set_interface_property s0 burstOnBurstBoundariesOnly false
set_interface_property s0 holdTime 0
set_interface_property s0 isMemoryDevice false
set_interface_property s0 isNonVolatileStorage false
set_interface_property s0 linewrapBursts false
set_interface_property s0 maximumPendingReadTransactions 0
set_interface_property s0 printableDevice false
set_interface_property s0 readLatency 0
set_interface_property s0 readWaitTime 1
set_interface_property s0 setupTime 0
set_interface_property s0 timingUnits Cycles
set_interface_property s0 writeWaitTime 0
set_interface_property s0 ASSOCIATED_CLOCK clock
set_interface_property s0 ENABLED true
add_interface_port s0 avs_s0_address address Input 8
add_interface_port s0 avs_s0_read_n read_n Input 1
add_interface_port s0 avs_s0_readdata readdata Output 32
add_interface_port s0 avs_s0_write_n write_n Input 1
add_interface_port s0 avs_s0_writedata writedata Input 32# | # +-----------------------------------
here is my VHDL code
-- Dust_Detect.vhd
-- This file was auto-generated as a prototype implementation of a module
-- created in component editor. It ties off all outputs to ground and
-- ignores all inputs. It needs to be edited to make it do something
-- useful.
-- This file will not be automatically regenerated. You should check it in
-- to your version control system if you want to keep it.
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity Dust_Detect is
port (
clk : in std_logic := '0'; -- clock.clk
reset_n : in std_logic := '0'; -- .reset_n
avs_s0_address : in std_logic_vector(7 downto 0) := (others => '0'); -- s0.address
avs_s0_read_n : in std_logic := '0'; -- .read_n
avs_s0_readdata : out std_logic_vector(31 downto 0); -- .readdata
avs_s0_write_n : in std_logic := '0'; -- .write_n
avs_s0_writedata : in std_logic_vector(31 downto 0) := (others => '0') -- .writedata
end entity Dust_Detect;
architecture rtl of Dust_Detect is
type matrix_2D is array (0 to 3, 0 to 3) of unsigned (15 downto 0);
signal cnt_dust_A : matrix_2D ;
constant fixA_array : matrix_2D :=(
(x"0000000D",x"0000000E",x"0000000F",x"00000010"),
(x"00000009",x"0000000A",x"0000000B",x"0000000C"),
(x"00000005",x"00000006",x"00000007",x"00000008"),
(x"00000001",x"00000002",x"00000003",x"00000004")
begin
MUX_matrix : process (clk, reset_n)
variable P_line : integer range 0 to 3 ;
variable P_column : integer range 0 to 3 ;
begin
if reset_n = '0' then
P_line := 0 ;
P_column := 0 ;
elsif rising_edge (clk) then
if avs_s0_write_n = '0' then
case avs_s0_writedata is
when x"00000000" =>
P_line := 0; P_column := 0;
when x"00000001" =>
P_line := 0; P_column := 1;
when x"00000002" =>
P_line := 0; P_column := 2;
when x"00000003" =>
P_line := 0; P_column := 3;
when x"00000010" =>
P_line := 1; P_column := 0;
when x"00000011" =>
P_line := 1; P_column := 1;
when x"00000012" =>
P_line := 1; P_column := 2;
when x"00000013" =>
P_line := 1; P_column := 3;
when x"00000020" =>
P_line := 2; P_column := 0;
when x"00000021" =>
P_line := 2; P_column := 1;
when x"00000022" =>
P_line := 2; P_column := 2;
when x"00000023" =>
P_line := 2; P_column := 3;
when x"00000030" =>
P_line := 3; P_column := 0;
when x"00000031" =>
P_line := 3; P_column := 1;
when x"00000032" =>
P_line := 3; P_column := 2;
when x"00000033" =>
P_line := 3; P_column := 3;
when others => NULL ;
end case ;
end if ;
if avs_s0_read_n = '0' then
avs_s0_readdata <= std_logic_vector(fixA_array(P_line,P_column)) ;
else
avs_s0_readdata <= "ZZZZZZZZZZZZZZZZ";
end if ;
end if ;
end process MUX_matrix;
end architecture rtl; -- of Dust_Detect
That is just a basic code to test some matrix storage. I want to send (with my application) a code which is decode as a line and column number and then put the corresponding number of the matrix in readdata. here is my C Code :
for (i=0;i<4;i++) {
for (j=0;j<4;j++) {
if ((i == 0) && (j == 0)) { n_case = 0x00000000; }
else if ((i == 0) && (j == 1)) { n_case = 0x00000001; }
IOWR(DUST_DETECT_S0_BASE, 0, n_case);
pos = sqrt(TAILLE_MATRICE)*i+j;
matrice = IORD(DUST_DETECT_S0_BASE,0);
Thank you, vvh
