15 years agocustom component with DCFIFO
Dear nios user!
I had associated a custom component(with DCFIFO) to Nios2 system. I used avalon MM slave interface and conduit interface. My custom component is module fifo_in ( // Avalon clock interface siganals input csi_clockreset_clk, input csi_clockreset_reset_n, // Signals for Avalon-MM slave port input avs_s1_address, input avs_s1_chipselect, input avs_s1_read, output [31:0] avs_s1_readdata, input avs_s1_write, input [31:0] avs_s1_writedata, // Signals export to top module input avs_s1_export_clk, input avs_s1_export_req, input [31:0] avs_s1_export_capture_readdata ); fifo_32 u1( //read side .q(avs_s1_readdata), .rdclk(~csi_clockreset_clk), .rdreq(avs_s1_read), //write side .data(avs_s1_writedata), .wrclk(~csi_clockreset_clk), .wrreq(avs_s1_write) ); endmodule My Source Code is for(i=0; i<0x10; i++) IOWR(FIFO_IN_0_BASE, 0, i); for(i=0; i<0x10; i++) printf("0x%08x ", IORD(FIFO_IN_0_BASE, 0)); This is FIFO read and write is OK. But, my custom component is modified. Modified custom component is module fifo_in ( // Avalon clock interface siganals input csi_clockreset_clk, input csi_clockreset_reset_n, // Signals for Avalon-MM slave port input avs_s1_address, input avs_s1_chipselect, input avs_s1_read, output [31:0] avs_s1_readdata, input avs_s1_write, input [31:0] avs_s1_writedata, // Signals export to top module input avs_s1_export_clk, input avs_s1_export_req, input [31:0] avs_s1_export_capture_readdata ); fifo_32 u1( //read side .q(avs_s1_readdata), .rdclk(~csi_clockreset_clk), .rdreq(avs_s1_read), //write side .data(avs_s1_export_capture_readdata),.wrclk(avs_s1_export_clk),
.wrreq(avs_s1_export_req) ); endmodule Modified custom component's read value is 0x00000000 0x00000000 0x00000000 0x00000000 .... Please help me. Thank you.
1 Reply
I have tested input data that is camera signal.
avs_s1_export_capture_readdata is camera's image data. avs_s1_export_clk is camera's PIXCLK. avs_s1_export_req is camera's HSYNC and VSYNC. I get exactly above signal(camera image data, PIXCLK, HSYNC, VSYNC). What is wrong? Please help me...
