16 years agoCreating subsystems
Is it possible to create subsystems in Simulink out of DSP blocks and not have it use the standard simulink IO blocks? If its not, when using the signal compiler with several sub systems created usin...
16 years agoSubsystem inputs and outputs should be handled correctly by Signal Compiler so long as you have DSP Builder Input and Output blocks at the outer boundaries of your design.
Just give it a go - it shouldn't take too long to create a system demonstrating this.
