16 years agoCreating subsystems
Is it possible to create subsystems in Simulink out of DSP blocks and not have it use the standard simulink IO blocks? If its not, when using the signal compiler with several sub systems created usin...
16 years agoAll Im asking is - If I have a subsystem made out of DSP builder blocks, it puts standard simulink input and outputs on the block. What Im concerned about is if I connect severeal of these subsystems together (all created from DSP builder blocks, but have standard inputs and outputs) is the signal compiler going to connect these together as I intend? or does synthesis stop at DSP builder IO blocks?
