16 years agoCRC compiler-error message
Hi, guys,
I am following the "CRC compiler user guide" to see the CRC generator and checker simulation. I got the following error message when I was trying to compile and simulate the crcdemo.v error: can't generate netlist output files because the file "d:/fyp_extra/crc_project/testbench/new_project_testbench/incremental_db/compiled_partitions/crcdemo.root_partition.map.atm" is an opencore plus time-limited fileerror: can't generate netlist output files because the file "d:/fyp_extra/crc_project/testbench/new_project_testbench/incremental_db/compiled_partitions/crcdemo.root_partition.map.atm" is an opencore plus time-limited file
error: can't generate netlist output files because the file "d:/fyp_extra/crc_project/testbench/new_project_testbench/incremental_db/compiled_partitions/crcdemo.root_partition.map.atm" is an opencore plus time-limited file It seems like the OpenCore plus feature expires? I don't quite get it. Thanks in advance
