14 years agoCPRI IP - cpri_clkout problem
Hi there,
I am new to Altera forums, so if you can please bare with me that will be great. I am currently working on a CPRI IP and trying to analyse the cpri_clkout signal from the IP after resetting it through NIOS. I am using Quartus II vers11.1 SP1 I have attached the Signal tap file with this thread. For some reason the cpri_clkout signal seems to go haywire after the reset structure is implemented. Can you please help why this might be happening?2 Replies
what clock frequency are you using to sample the signals in signal tap? If the sample frequency is close to your cpri_clkout then the reading in signaltap doesn't mean anything. Either use a higher frequency clock or use a real scope on the FPGA pin.
Thanks Daixiwen, problem solved.
I just had to tie down gxb_powerdown signal, by doing so the cpri_clkout dint reset itself.
