14 years agoCPRI IP - cpri_clkout problem
Hi there, I am new to Altera forums, so if you can please bare with me that will be great. I am currently working on a CPRI IP and trying to analyse the cpri_clkout signal from the IP afte...
14 years agowhat clock frequency are you using to sample the signals in signal tap? If the sample frequency is close to your cpri_clkout then the reading in signaltap doesn't mean anything. Either use a higher frequency clock or use a real scope on the FPGA pin.
