16 years agoConvert m file to verilog/vhdl?
Hi Guys, Is there any way to convert Matlab .m code to verilog or vhdl? Does DSP builder only compile simulink file? Thanks Jerry
16 years agoits not even as simple as that.
M code is inherently procedural, like C. VHDL/verilog are description languages and are parallel languages. If you want to convert from simulink to HDL code you have to design your algorithm appropriatly, usually with the involvement of a hardware engineer.
