15 years agocontrol packets issue in dsp builder
Hi
I am working on video and image processing project. I am using quartus II v6.0 and dsp builder. I have used deinterlacer, chroma resampler, color space converter and scaler megacore function between two avalon streaming interfaces as it is shown in the figure. I want to process video data packets only, so I have to import a custom logic block(vhdl or verilog file) in between deinterlacer and chroma resampler, but the problem is I donot know before the video packets either the control packets are coming or not. How Custom logic block(vhdl or verilog file) can differentiate between video and control packets?????? I donot know how to handle this issue of control packets!!!!!!!! If you have any idea please let me know. Thank You1 Reply
AoA Rizwan sb
I am Rafi from Lahore Pakistan. I can not any help for you. Because i am a biggner in FPGA. If you can my help? please tell me about Quartus II, SOPC Builder and Nios II Eclipse Plateform. When i press the button "submit reply" then occure error message "please remove e-mail addresses from your message, then you will be able to submit your post." my email address is "srafi56 at the rate of yahoo dot com" Thank you Rafi
