9 years agoconnecting 32 bit data to 128 bit data with avalon
I think it maybe a silly problem but I can't get it work. I want to connect my master with 32 bit datawidth to a ddr controller with 128 datawidth using qsys. But when I simulate it in modelsim, it s...
9 years agoI've had similar issues with the Altera DDR3 controller getting stuck and never asking for data when connected to Avalon-MM interconnect fabric - they don't seem to like each other very much.
I made the attached Qsys IP core which allows narrow masters to connect to wide slaves. It seems to do the trick for me at least, so might be worth a try. Just select the Qsys parameters for the module to ensure that the output interface sideband signals match the DDR signals so that no fabric is inserted between.
