15 years agoConfliction on reading and refreshing request on DDR2 SDRAM Controller
I am using the DDR2 SDRAM Controller generated by Megawizard of Quartus9.1. The basic reading and writing request can successfully processed by controller, but, when the reading request is en...
15 years agoIf you are using the HPCII then the controller has a command fifo 8 commands deep. If the memory is busy refreshing then this fifo may get full and the controller will deassert local_ready at which time you cant issue any further commands.
I've never seen the X after refresh is finished however??
