18 years agoConfiguring triple speed ethernet MAC with National DP83848 PHY in MII interface
Hi I am trying to make a design with a triple speed ethernet MAC from Altera work. I am using a National DP83848 PHY and the small 10/100 version of the MAC. I have attached a snapshot of my sc...
15 years ago --- Quote Start --- Hi teilersen, I have made my own custom Cyclone III Nios board with the DP83848 PHY and it works fine. I also used the TSE MAC from Altera. I began with the simple socket server project and then I moved on the webserver project. Did you success in your project? I can help you if you have any questions.. Just a last thing, did you configure a system clock in SOPC builder, UCOSII and Interniche need this feature to work.. Regards, -Pierre --- Quote End --- Now I do the same work as you did,Can I communication with you though private email?
