18 years agoConfiguring triple speed ethernet MAC with National DP83848 PHY in MII interface
Hi I am trying to make a design with a triple speed ethernet MAC from Altera work. I am using a National DP83848 PHY and the small 10/100 version of the MAC. I have attached a snapshot of my sc...
16 years agoAfter contacting support for the board manufacturer and National Semi support, we're returning our board for replacement, suspecting defective DP83865DVH devices.
Board manufacturer support said this was a "known problem" and are reworking boards to resolve. Temporary work around was to force the negotiated speed to 100 Mbps or below. Didn't work for us. One device showed a negotiated speed of 100 Mbps but still didn't work in the tx direction. The other device stayed at 1 Gbps (though it was never connected to anything capable of 1 Gbps) and showed no signs of life. Both devices were very hot to the touch from the first time they were configured. National Semi support said getting very hot in a few seconds means a faulty DP83865DVH part or possibly a board problem -- should return to board mfgr. Also, here's a thread on another forum where defective DP83865 devices are discussed: listsDOTgnuDOTorg/archive/html/discuss-gnuradio/2010-04/msg00603.html
