18 years agoConfiguring triple speed ethernet MAC with National DP83848 PHY in MII interface
Hi I am trying to make a design with a triple speed ethernet MAC from Altera work. I am using a National DP83848 PHY and the small 10/100 version of the MAC. I have attached a snapshot of my sc...
17 years ago --- Quote Start --- Hi teilersen, I have made my own custom Cyclone III Nios board with the DP83848 PHY and it works fine. I also used the TSE MAC from Altera. I began with the simple socket server project and then I moved on the webserver project. Did you success in your project? I can help you if you have any questions.. Just a last thing, did you configure a system clock in SOPC builder, UCOSII and Interniche need this feature to work.. Regards, -Pierre --- Quote End --- Hi Pierre my problem is as following: nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) =============== Software License Reminder ================ This software project uses an unlicensed version of the NicheStack TCP/IP Network Stack - Nios II Edition. If you want to ship resulting object code in your product, you must purchase a license for this software from Altera. For information go to: "http://www.altera.com/nichestack" ===================================================== InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x00000400 INFO : PHY National DP83848C found at PHY address 0x1f of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 100, Duplex = Half OK, x=0, CMD_CONFIG=0x01000000 MAC post-initialization: CMD_CONFIG=0x05000603 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created IP address of et1 : 0.0.0.0 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) DHCP timed out, going back to default IP address(es) Simple Socket Server starting up at the same time , i don't know why the DP83848 is very hot? thanks!
