18 years agoConfiguring triple speed ethernet MAC with National DP83848 PHY in MII interface
Hi I am trying to make a design with a triple speed ethernet MAC from Altera work. I am using a National DP83848 PHY and the small 10/100 version of the MAC. I have attached a snapshot of my sc...
18 years agoThanks for the quick reply! One last question: the DP83848 isn't 100% clear on its 25MHz clock output. Since it has a power-on reset, that clock should be present upon powerup. Can this therefore be used to clock the FPGA and its PLL's directly, thereby eliminating the need for an extra oscillator for the FPGA? Or is this a little dangerous?
Thanks, Pierre
