18 years agoConfiguring triple speed ethernet MAC with National DP83848 PHY in MII interface
Hi I am trying to make a design with a triple speed ethernet MAC from Altera work. I am using a National DP83848 PHY and the small 10/100 version of the MAC. I have attached a snapshot of my sc...
18 years agoHi all,
Quick question about the PHY connection: is it necessary to take the TX & RX clock pins to global clocks netword on the Clkin pins on the FPGA (or DPCLKs), or can normal IO's be used? Thanks, Pierre Watts
