13 years agoComplex Coefficients with FIR Compiler II
Is it possible to use complex coefficients with the FIR Compiler II? If so, what notation is used to specify this when loading coefficients from a file into the wizard? I've tried i and j, but the wizard is complaining about invalid coefficients.
--- Quote Start --- Is it possible to use complex coefficients with the FIR Compiler II? If so, what notation is used to specify this when loading coefficients from a file into the wizard? I've tried i and j, but the wizard is complaining about invalid coefficients. --- Quote End --- I know dspbuilder doesn't support complex filter but you can use four real filters and do the complex addition/subtraction manually. remember for every tap the following multiplication is needed: yr = xr.hr - xi.hi yi = xr.hi + xi.hr thus the terms xr.hr becomes one filter for these inputs and the term xi.hi a second filter and so on. Finally you add/subtract the outputs of two pair filters to get real and imag output. You can alsouse three filters by some trick. - Altera_Forum
i don't think FIR II supports complex data paths
thanks guys
