15 years agocompilation problem in simulation
im using triple speed ethernet megacore to bring up rgmii interface with phy and i want to check how loopback is working in simulation while im complilng im not able to compile the altera_tse_t...
15 years agoThose files should be in C:/altera/10.0/ip/altera/triple_speed_ethernet/lib. In the path, the drive "C:" should be whatever drive your tools are installed on, and the version "10.0" should be whatever version you're using. Caution: those files are encrypted, and you may not be able to compile them. I'm running into that problem with my own TSE simulation ( you can see my thread on this forum )
