15 years agoCompilation fft library in ModelSim
Hi, I am trying to build the fft library in ModelSim... I am following the instruction in previous posts of others to compile the file ./fft_pack_fft_90.vhd in modelsim so that i can use to compile t...
15 years agoi think the .vho should be compiled into the work library, not into its own library
let me go through a simulation flow to see if i can figure out where your problem is. to be honest i usually use NativeLink and edit the generated .do file to my needs
