15 years agoCompilation fft library in ModelSim
Hi, I am trying to build the fft library in ModelSim... I am following the instruction in previous posts of others to compile the file ./fft_pack_fft_90.vhd in modelsim so that i can use to compile t...
15 years agoThe file fft_h_1n64cos.hex is already in the same directory of the <fft core>.vhd in my computer. I compiled everything in the ModelSim and I didnt copy any files manually into the work folder.
My step is firstly create a new library fft_lib and compiled the file <fft core>.vho. Secondly, I compiled the <fft core_tb>.vhd in the work folder. After these 2 steps, I open the <fft core_tb>.vhd I attached again the log file. The 1st log file was shown when I double click the <fft core_tb>.vhd file in the work folder. The second log file was shown when I run the simulation. Hope you can troubleshoot my problem... Thanks.
