15 years agoCompilation fft library in ModelSim
Hi, I am trying to build the fft library in ModelSim... I am following the instruction in previous posts of others to compile the file ./fft_pack_fft_90.vhd in modelsim so that i can use to compile t...
15 years agoHi, I attached the complete log that was shown when I tried to run the simulation using the generated testbench file.
What is the meaning of .do file? I am using the ModelSim starter edition, because inside the modelsim doesnt have fft_lib library, So initially I followed your advice to compile the .vho file to include the fft library to the modelsim.. after that, I compiled the <fft core>.vhd and the <test bench>.vhd in work folder. Then I run simulation on the testbench file, then i select option "add to wave all items in region" then I click on start simulation... The resulting error message occurs.
