15 years agoCompilation fft library in ModelSim
Hi, I am trying to build the fft library in ModelSim... I am following the instruction in previous posts of others to compile the file ./fft_pack_fft_90.vhd in modelsim so that i can use to compile t...
15 years agocan you post more of the log? are you doing the whole process manually or is there a .do file? are you trying to vcom altera_mf.vhd? ModelSim-A(S)E shouldn't require this step, the libraries are precompiled and installed
