15 years agoCompilation fft library in ModelSim
Hi, I am trying to build the fft library in ModelSim... I am following the instruction in previous posts of others to compile the file ./fft_pack_fft_90.vhd in modelsim so that i can use to compile t...
15 years agoi suspect you are trying to compile the encrypted core source. you need to enable generation of the simulation model netlist in the MegaWizard, and compile the generated <instance_name>.vho in your ModelSim project instead of the <instance_name>.vhd and its associated libraries
