16 years agoColor Plane Sequencing
Hello, I'm trying to utlize the Median Filter in SOPC. I've managed to connect a Clocked Video Input module to a Clocked Video Output Module no problem and pass-thru video data. So CVI -> CVO...
16 years agoAre you sure your clock rate is high enough? The section of the VIP chain where the video planes are in sequence will require a higher clock rate than when everything is parallel.
