14 years agoClocked Video Output bug?
This has been bothering me for a while and I'm wondering if others have seen the same: In short, the output HS/VS from the clocked video output are not aligned. No matter what I do in the actua...
14 years agoWhat is the exact board, or IP block you are using? It sounds like it's a bug in the IP, so I would make Altera or the IP provider aware of it.
I've done video retimers in the past in an FPGA, and can tell you old CRT's are much more forgiving than most LCD flat panels. Pete
