16 years agoClocked Video Output behavior
Hi I designed a system with following flow: Clocked Video In (CVI) --------> Frame Buffer ------------> Clocked Video Out (CVO) Input video format is 1080p 60Hz. For frame buffer, I a...
16 years agoCould I ask you how did you set up frame buffer?I have troubles using the sdram with it, I don't know wich clock should I use.
