16 years agoClocked Video Output behavior
Hi I designed a system with following flow: Clocked Video In (CVI) --------> Frame Buffer ------------> Clocked Video Out (CVO) Input video format is 1080p 60Hz. For frame buffer, I a...
16 years agoI don't know for sure, but I would guess the blank frame is generated by the frame buffer, not the CVO. You could try removing the frame buffer to see if you still get the blank frame. Connecting a test pattern generator straight to the CVO may also be an interesting experiment.
