17 years agoClocked Video IP for NTSC bt656
Hello everyone,
I desperately need help with getting my embedded sync bt656 clocked out IP to work. I have connected the test generator module found in the VP 8.0 reference example, and connected it to the Clocked Out video ip. Then connected the Video output 8 bit bus to my ADV7171 video IC.( which has been tested with its internal color bar.) The test generator is set to send := 422 ycrcb 720 by 486 The Video Clocked out IP is set to Embedded sync mode, 720 by 486 active picture and 8 bit , 2 symbols per beat and interlaced. synce field one is Active Picture line=20 Horizontal Blanking =138 Vertical Blanking = 20 Field zero F rising=266 F falling =4 vertical blanking rising edge line =264 vertical blanking =19 All I end up getting is a black screen, and when brightness is turned up it is light green vertical lines. Please can some one help me with this problem , it will be greatly appreciated. regards, Nadeem
