17 years agoClocked Video IP for NTSC bt656
Hello everyone, I desperately need help with getting my embedded sync bt656 clocked out IP to work. I have connected the test generator module found in the VP 8.0 reference example, and c...
13 years ago --- Quote Start --- I finally moved both the TPG and CVI blocks to a the Quartus II block level (BSF). --- Quote End --- How did You do that? Created the connections in QSYS and then generated *.bsf or You did not use QSYS at all?
