17 years agoClocked Video IP for NTSC bt656
Hello everyone, I desperately need help with getting my embedded sync bt656 clocked out IP to work. I have connected the test generator module found in the VP 8.0 reference example, and c...
13 years agoThe other thing you may want to look at in the data sheet is the i2c MPU port.
You may need to set some registers inside the chip appropriately in order to have it generate video correctly. Also, it looks like you may be able to have the chip generate a color test pattern internally and output it to your monitor. You may want to try and get this feature to work before sending it video from your FPGA.
