17 years agoClocked Video IP for NTSC bt656
Hello everyone, I desperately need help with getting my embedded sync bt656 clocked out IP to work. I have connected the test generator module found in the VP 8.0 reference example, and c...
17 years agoSorry I am not familiar with the IP cores you are using but this article on inserting BT656 TRS codes may help, http://www.singmai.com/sdi.htm.
If you are getting a green screen then that normally indicates the Y and C are swapped.
