17 years agoClocked Video IP for NTSC bt656
Hello everyone, I desperately need help with getting my embedded sync bt656 clocked out IP to work. I have connected the test generator module found in the VP 8.0 reference example, and c...
17 years agothanks for your response.
Yes i do seem to be getting video data out, but not sure if it correct. I know that the the video IC is doing something as it is definitely sending a signal to myscreen. I was little confused by the question of using 10 bits and 2 symbols or 8 bits and 2 symbols. not sure what the 10 bits , standard altera settings are for? I am not even sure if my Blanking setting are right. regards nadeem
