16 years agoClock-Error --> Two ports have different clocks, where they should have the same
Hi People, I make a filterbank with 32 IIR-bandpassfilter --> 32x16 coefficient. the application is a mp3-encoder/decoder in dsp-builder. I have resolt my schematic with LUT for reduce mul...
15 years agoMATLAB 2010a is only supported by DSP Builder 10.1+. i'm not sure if that is causing the issue you are seeing here but i have run into problems using 2010a when it wasn't yet supported
what device are you targeting? i also remember an issue with Cyclone IV GX PLLs in DSP Builder which should also be fixed in later software
