16 years agoClock-Error --> Two ports have different clocks, where they should have the same
Hi People, I make a filterbank with 32 IIR-bandpassfilter --> 32x16 coefficient. the application is a mp3-encoder/decoder in dsp-builder. I have resolt my schematic with LUT for reduce mul...
16 years agoI have the same problem. Now i have replaced the Clock_derived block with a PLL but I can't configure it correctly.
The main clock is the 48kHz The output clock has: period multiplier = 32 period divider = 1 that should create a 1'536 MHz clock. Error message into the PLL configuration window: Cannot implement configuration. Why? What is wrong? Is there somewhere an example? Thanks in advance
